Room Available for ROMEOs Rendezvous
roginoz
Post by roginoz »
I'm going to have to cancel my trip to Grove. The ST1300 is apart for valve adjustments (one exhaust valve clearance out of spec on each bank of cylinders, so I have to pull both exhaust cams...) and I don't think that I'll have it together for a Tuesday departure. (I've checked the clearances before, but this is my first time to pull the cams and re-shim the followers.) I'm going to complete some other maintenance while all the body work is off, too.
I'm not sure how fully booked the motel is; if someone needs a room, I've just cancelled mine:
Stonebrook Inn
10400 Hwy 59 N
Grove, OK 74344
(877) 868-9799
(918) 786-9788
carymca
Re: Room Available for ROMEOs Rendezvous
Post by carymca »
There is another room available, as I have also cancelled mine. John and I were going down together, but wet, stormy forecast is not good and I don't need more experience riding in the rain.
Cary
